Where to check oil pressure?
Im going to be getting a mechanical oil pressure gauge. Do you just screw it in where the sensor goes? I would think that would be a pain,any other spots on an ls1?
Alex
Alex
The bypass plate above the oil filter is the best place to do this since there is already a boss there to drill and tap. of course be sure to remove all metal shavings from the plate before reinstall and to use thread tape on the fitting.
