Wd40 used on engine internals...
Old 09-21-2007, 12:53 AM
pretzeljuice's Avatar
Default Wd40 used on engine internals...
Hi all, I pulled my engine out of my car awhile back to do a freshen up on it and I have a question.
I have my engine on the stand and decided to spray wd40 on the bottom of the engine including the rods,rod bolts,crank,mains and main bolts to keep it lubed for a few days before I throw the oil pan back on and put it back in the car.
Spraying wd40 won't penetrate the rod bolts or main bolts and make them loose will it?
I am going to coat everything with motor oil before I put it back in the car but want to make sure that the wd40 won't cause my bolts to loosen up.
Sounds dumb I know but just want to make sure.
Old 09-21-2007, 08:00 AM
wags98's Avatar
Oh man your screwed!!!!!!!! LOL I dont think youll have a prob...I wouldn t worry too much about it get that thing together and go kick some *** man....
Old 09-21-2007, 09:48 AM
Steel Chicken's Avatar
wd works better as a water repellent than as a lube.
Old 09-21-2007, 10:55 AM
gmguy4life's Avatar
Motor oil works just fine by itself.
Old 09-21-2007, 12:21 PM
GuitsBoy's Avatar
You shoudl be fine.
Old 09-21-2007, 05:24 PM
R u guys sure? I would have poured motor oil on the bottom if I had any layin around. I had a can of wd40 so I used that. I just want to make sure it wont cause my bolts to become loose.
Thanks
Old 09-22-2007, 02:20 PM
BigKap94z's Avatar
You will be fine.
Old 09-22-2007, 11:27 PM
RoDan's Avatar
wd40 sucks, it wont make anything loose that wasn't about to be in the first place. You'll be fine!
Quick Reply: Wd40 used on engine internals...
