Cam Swap in stock 2000 WS6
Old 09-21-2007, 01:22 PM
camaro_fanatic2003's Avatar
Cool Cam Swap in stock 2000 WS6
I am looking at changing the cam in my 2000 WS6. So far I am interested in the COMP Cams Xtreme XE-R Camshaft
Camshaft, Hydraulic Roller Tappet, Advertised Duration 273/ 279, Lift .581/ .588
Does anyone know anything about this cam?
Is this cam too big for a stock LS1?
Any other suggestions for making some good street/strip power?
Old 09-21-2007, 01:29 PM
Hennytime's Avatar
headers first, and its WAYYYY too big even imo for a 427, look for something in a 22x/23x area
Old 09-21-2007, 02:04 PM
Dragkid1917's Avatar
maybe thats the duration at .006 and not .050. If its not thats upsurdly big, thats a big block type cam
Old 09-21-2007, 03:05 PM
GuitsBoy's Avatar
I can only imagine those are advertised numbers @.006 since the lift dosnt even break .600
Old 09-21-2007, 03:38 PM
HAZ-Matt's Avatar
If you didn't already, take a look at that recent thread about the reverse Torquer cam which was mostly a discussion of reverse split cams in general. There were some good suggestions in there.
https://ls1tech.com/forums/generation-iii-internal-engine/652563-reverse-torquer-cam-other-side-coin.html
Old 09-21-2007, 04:28 PM
02WS6_TA's Avatar
No that's the advertised duration, the duration a 0.50 is 224/230. In my opinion no that's no to big for a stock car, but if I 'm thinking correctly that cam isn't computer compatible so you'll HAVE to get a tune. With that in mind you'll have to upgrade you're valve springs, and invest in a set of long tube headers. That cam should have good power gains since the Comp lobes are renowned for making more power than similar cams with the same duration and lift. The XE-R cams also carry more vaccum throughout that helps you keep your brake booster up to operating specs to guarantee proper operation.
Done research on this cam before I decided on the one I bought, great camshaft IMO
Old 09-21-2007, 11:38 PM
yeah, im pretty sure it is the same as the 224/230. i found it on another site that called it that. 02WS6_TA, what cam did you decide on? just wondering. this cam was just a thought, if anyone knows of a better one, let me know, thanks.
Old 09-21-2007, 11:40 PM
also, i was already planning on changing out the springs when i did the cam swap.
Old 09-22-2007, 03:37 AM
uncle ray's Avatar
whats the lsa? i have the crane 224/224 .551/.551 114 lsa. it does 340whp on a nitrous tune (timing retarded) and 377tq. should be around 360whp with full timing. it sounds completely stock at idle, nice and quiet. on a 150 wet shot it did 507whp, and 616tq!!! however this cam runs out of breath right at 5800rpm. your cam should get you the same numbers... enjoy!!!
oh and this cam is actually tiny for an ls1. ive heard people passing smog on it!
Old 09-22-2007, 03:40 PM
well maybe i should go bigger then, i want it to sounds like an old school hot rod. i want crazy sounding lopes. i dont know abything else about the cam,thats all that i found on it was what i posted. i also didnt have a ton of time to research it either.
Old 09-22-2007, 05:06 PM
COD02SS's Avatar
Just don't go too far or you'll loose drive ability
Old 09-22-2007, 06:20 PM
whats the biggest i should go and still be a daily driver? i want to keep something to be considered gas milage, and i want it to be able to idle fine, but still sound nasty and put down good numbers.
Old 09-23-2007, 03:37 PM
02WS6_TA's Avatar
I ended up buyin the F15 cam with .600"/.611" 236"/239 @0.50 and a 111 lsa,but mines not a daily driver either. I simply went this big because I wanted something that pulls hard on the top end and the hotrod sound you pointed out.
Old 09-23-2007, 05:52 PM
who is that made by? would it not make a very good dd cam?
Old 09-23-2007, 05:55 PM
camscam02's Avatar
get longTubes first!
Old 09-23-2007, 09:08 PM
02WS6_TA's Avatar
The F15 is made by futral motorsports. Anything that high of a lift, you're probably going to suffer a little driveability. The key to any cam is a good tune though. Check out Futral's site they have an entire list of custom ground cams that'll probably catch your eye, www.futralmotorsports.com. Oh yeah and you definately need a set of longtubes, you'll thank us later.
Old 09-24-2007, 12:25 AM
after thinking about it, i had just recently decided to get lt's and an intake first thing. that should help with getting the tune just right too shouldnt it? i think im going to make my exhaust true duals, what do you guys think? after those, i will go ahead with the cam.
Old 09-24-2007, 10:46 AM
ttt...still need input.
Old 09-24-2007, 10:52 AM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Lightbulb
X 2 For sure...LT's..then a CAM.
Old 09-24-2007, 10:53 AM
ls1ws9ta's Avatar
if drivability is a concern I would go with a z06 package. 2002 z06 cam, ls6 intake, and the ls6 heads. with Longtubes and a tune you should be at 400rwhp...car will sound and idle stock but have the power there.
