Advantages of a better flowing exhaust port?
I was comparing the Et 215 heads and the Trickflow 215s. The intake port flow numbers are almost identical, within 1 or 2 cfm. But the exhaust port, the trickflow really outshined the ets.
I know power is made with the right cam and head combo, but forgive me if i am being ignorant, why would i buy ets if the trickflows out flow them so much on the exhaust side reguardless of cam selection?
You mentionned why at first but then went backwards saying "regardless of cam selection".
Think of the cam as the heart and the heads as the lungs. One cannot be efficient without the other. so while the heads will put out numbers with any cam a custom cam is better suited for specific head designs.
I believe Trick Flows are flowed with a pipe on the exhaust which increases the numbers.I would check to make sure you are comparing the same numbers.Some one may know about how much a pipe increases flow but I would guess these heads are close on the exhaust also.
