push rod help
push rod help
checking push rod length exhaust 7.335 intake 7.315 without preload added using comp cam oem lifters tfs 225 heads harland sharpe rockers what length pushrod should i get
tea says 7.5's or 7.7's depending on the casting marks. on my engine they used 7.5's. i think in other threads if the casting are A or B its 7.7's. if its C then its 7.5's. do a search to make sure the information is there
