head gasket thickness
Old 09-24-2007, 11:10 AM
Dragkid1917's Avatar
Default head gasket thickness
whats the stock head gasket thickness? I was wondering if just a simple swap in gaskets could raise the compression enough to make a diff or if i have to mill
Old 09-24-2007, 11:24 AM
mrclean200518's Avatar
if your heads are already off go for it but if not i dont think it would make a big enough difference to pull them off for
Old 09-25-2007, 10:26 AM
but do you know the stock gasket thickness?
Old 09-25-2007, 12:39 PM
PREDATOR-Z's Avatar
.052 crushed
Old 09-25-2007, 12:40 PM
ok so if i get a .040 then when its crushed itll probaly be what?...
and also do you know the cylendar head volume... im tryin to use a compression calculator and i need all that ****
