Need help car won't start.
I tried to start my Camaro after finally getting it back together enough to start. It wont start
98-A4 Camaro.
All the fuel has been out of the car. I have had it all apart and put back together now.
I turned the car on and off several times before starting and I hear the pump run.
When I press in the valve in the fuel rail it has no fuel come out so I'm thinking its not getting fuel.
Does the oil pressure supposed to read when your turning over the engine but it won't start. It sits it zero but I don't know if thats normal or not if its not actually running.
98-A4 Camaro.
I think this has to do with the pump now, could a mod move to fuel section please.
The oil pressure is ok now. I think its just needed more turns to get it thru the oil pump. It now goes up when turning over.
I think the problem is in the pump somewhere.
I pulled the line that goes to the fuel filter off of the fuel pump and turned the key. The I can hear the pump run but no fuel. There was not even any fuel come out when I unhooked the line from the top of the tank.
What could it be? everything looks ok
Originally Posted by vaticano
dumb question. but did you happen to put in a new pump and forget to hook it up inside the tank.
I took the pump out of the assembley, I stuck it is some gas and turned it on with the sock off. It runs but still does not pump. Its like the pump won't get a prime. I can look into the end of the pump where the sock goes and turn it on and see it spinning inside the pump.
I think I got it now. I turned the pump upside down and poured some fuel into the inlet. It sucked it thru. I stuck it back into the gas right side up and now it is pumping fuel out like it should.
edit: it fixed it, its running now.
