car wont start out of no where
Old 09-25-2007, 08:48 PM
camsom's Avatar
Default car wont start out of no where
i have a 99 TA A4 car was running good as always when i went to class came out to my car throwing a Throttle positioning sensor code, a crank positionsing sensor code , speed sensor code, and 1-2 shift solenoid code anybody have any ideas i need some help badly thanks
Old 09-25-2007, 10:25 PM
99blancoSS's Avatar
someone unplugged your ecu while the battery was connected ?
Old 09-25-2007, 10:41 PM
Hennytime's Avatar
check some power connections, mine did the same thing when a little roach got into the harness and chewed on something an fried himself. it sucked ***
Old 09-25-2007, 10:48 PM
Hennytime's Avatar
Old 09-25-2007, 11:00 PM
camsom's Avatar
What would I need to do if something did happen to the ecu?
I'm sorry to hear about the harness, everything I checked seems to be o.k., but I'll check it again.
Old 09-26-2007, 11:10 AM
99blancoSS's Avatar
start simple first... fuses.. A vendor on ebay has ecu for 115 delievered, programmed how ever you want. How about fuel pump or fuse?
Or could be a bad battery. Maybe a cell or two died. The ecu will act strange if it isnt getting good power. From the suddeness of it all I'd suspect that first. Have the battery checked.
Old 09-26-2007, 11:46 AM
deeloc1's Avatar
+1 on the bad battery...that's the first thing that came to mind when i read your first post.
Old 09-27-2007, 01:59 PM
camsom's Avatar
ttt................
Old 09-27-2007, 05:14 PM
99blancoSS's Avatar
Did you have the batt checked?
