what size cam for a 427 with a f1a procharger
Old 09-26-2007, 06:05 PM
Disturbed Bird's Avatar
Default what size cam for a 427 with a f1a procharger
what it says in the title.
Old 09-26-2007, 11:23 PM
anyone?
Old 09-26-2007, 11:36 PM
KCFormula's Avatar
What are your goals? high peak HP? Fast 6spd car? etc?
If you want something that is fast at the track just go solid roller and match it to the flow numbers on your heads.
Old 09-27-2007, 07:37 AM
something with good mid and top the bottom in power will be taken care of from the CI
i was thinking about a 240/248 115lsa but i think that might be a little small. any idea?
Old 09-27-2007, 09:23 AM
KONG's Avatar
You should PM partick G or predator Z about this.
Old 09-27-2007, 10:23 AM
blueeyeddevil141's Avatar
That sounds like the Vindicator lol, 240/244 113
Old 09-27-2007, 12:05 PM
Dumb Ass Vette Moderator
ls1290's Avatar
At least that. A 246/255//59x/60x//115 would be good.
Keith
Old 09-27-2007, 05:29 PM
LS1 Tech Administrator
Patrick G's Avatar
What's your bore and stroke?
Static compression?
What heads? Flow?
Spring type?
What kind of intake?
What size headers?
Cats?
What kind of exhaust going back?
Desired shift points?
Desired redline?
What kind of street manners? Light chop? Hard lope?
What kind of trans?
Clutch or converter size?
Rear gearing?
What percentage of street vs race?
Without knowing all these answers to these questions, you'll pretty much be guessing at cam size.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 09-28-2007, 12:30 AM
-What's your bore and stroke? not sure it will be in the warhawk block as a 427 and i think its 4.125 bore.
-Static compression? low compression for a f1a procharger
-What heads? Flow? worldcastings ls7x heads
-Spring type? most likely tripple valve springs
-What kind of intake? it will be a cone off a f1a procharger
-What size headers? 285cc
-Cats? no
-What kind of exhaust going back? longtubes with dual exhuast
-Desired shift points? does it matter?
-Desired redline? does it matter
-What kind of street manners? as long as it drives on the street Light chop? -Hard lope?
-What kind of trans?for right now it will be on a t56 but may got to a powerglide
-Clutch or converter size?
-Rear gearing? 4:10 may be higher
-What percentage of street vs race? mostly race
Old 09-28-2007, 01:43 AM
PREDATOR-Z's Avatar
-Cats? no
Without completing Patrick's questions to a T, there is no way to spec a cam. So your guess is as good as ours.
Put the list of combo mods down and we can help, otherwise what you'll end up with is a BALLPARK cam at best.
Old 09-28-2007, 01:49 AM
Websy21's Avatar
my buddy jsut got done a 427 n/a and made 540rwhp/530tq with a 244/248 113LSA, but probably doesn't help you much, lol. Stock, untouched L92 heads and L76 intake via M6. Like Pred said though, need exact specs, him and Pat G are the ****.
Quick Reply: what size cam for a 427 with a f1a procharger
