How can you tell the truck motors apart ?
I'm trying to buy a 5.3 truck motor and I spotted one in a junkyard but somebody aready removed it from the truck and they dont know if it's a 4.8 or a 5.3 .... ?? How can I tell just by looking at the motor.
Is there a way to tell the 4.8 / 5.3 / 6.0 apart by just looking at them ?
OWN3D BY MY PROF!
I know the 6.0s have 6.0 stamped into the side of the block. I remember reading the 4.8 / 5.3 thing on here a little while ago, but don't remember. I'll try searching for you.
EDIT: https://ls1tech.com/forums/showthrea...8+5.3+identify
Blamo! Quick and easy search. Took about 45 seconds.
Thanks I need to iron out my searching skills. I gave up after a few minutes.
Ok NOW.... Can you do this with the tranny still installed ????
Originally Posted by bigbls1
Look on the back side on the right side of the block it should tell you. 4.8,5.3,5.7,6.0...
Or take the pan off and get the crankshaft part number and call your local chevy dealer and he can tell you. The 4.8 has the shortest stroke of them all so it should be easy to tell. Good luck
