what are your thoughts on a 434 motor?
Old 09-28-2007, 05:13 PM
nomorews6's Avatar
Default what are your thoughts on a 434 motor?
I am looking at a car that has a 434 6.0 litre motor, and it makes killer power. Is there anything I should know about this kind of motor? What are your thoughts on it?
Old 09-29-2007, 04:05 PM
Indiana Z06's Avatar
As long as it's built right with the right parts, you shouldn't have problems. That being said, when you run a motor on ragged edge, there's always the possibility of breakage. What heads and cam are being used? How many miles on it? Was it broke in correctly? Good luck.
Old 09-30-2007, 12:09 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
How the hell is someone getting 434ci out of a iron block? Ask them what the bore and stroke is, heads, cam, valvetrain. Don't settle for I don't know. If they can't tell you pass. I'd pass anyways unless it's some freakishly good idea.
Old 09-30-2007, 11:09 AM
3fingas's Avatar
bigger is better
Old 09-30-2007, 11:40 AM
99blancoSS's Avatar
Details on the motor who built it being the most important.
Old 10-01-2007, 09:39 PM
DAVESS02's Avatar
Originally Posted by 3fingas
bigger is better
and too much is just about right!
Old 10-02-2007, 07:15 AM
slow trap's Avatar
i'm interested to know on the bore/stroke also. if they used a 4.125" stroke it would have to be bored .090" over.
a .060" is a 427 and i would consider that much overbore leaving the walls pretty thin. hmmmmmm.....
Old 10-02-2007, 01:28 PM
OWN3D BY MY PROF!
Join the club. I seriously doubt it's a 434. Doing some backwards math I figured you'd have to be running a 4.20 stroke and a 4.050 bore. It's some what believable, but it would be a major oil burner. I think you're being BSed.
Old 10-02-2007, 01:35 PM
DONAIMIAN's Avatar
Sounds fishy coming from an FE block.
Guess you couldn't go too long without something fast huh? lol.
