Ms4/stg 1 Heads Install
Old 09-30-2007, 06:43 PM
ponyeater01LS1's Avatar
Default Ms4/stg 1 Heads Install
I did the install started it up last night and I am getting a lopey spitting sound on the drivers side?? We all think its the header gasket leaking from the rear 2 ports. Just getting second oppinions here, when it gets rpms it quits, only does it when idle. drove the car for about 3 hrs today off and on no probs but this sound at idle. Throw your .02 in it will help my worrying hahaha
Old 09-30-2007, 07:49 PM
Prerun4fun13's Avatar
Probably just an exhaust leak, what header gaskets are you using? Has the car been tuned yet?
Old 09-30-2007, 08:21 PM
not tune yet and im using copper gaskets that came with pacesetter hedders, gaskets are brand new but they look like the crush type and u can see a very ity bity small gap in the gasket where it didnt crush down
Old 10-01-2007, 07:16 PM
Robison_'02-SS's Avatar
Just a question, Did you get the gasket the right way? I got the same headers and gaskets and i almost put them on the wrong way.That would create a seal problem.And it took a while to get all the leaks on mine fixed, tightened where it leaked every time, but now its good.
Old 10-01-2007, 07:23 PM
6']['9's Avatar
i have the same set up and it does the same thing. it stutters at start up then dies, if i drive it it rides fine. But it feels like theres a misfre somewhere.
Old 10-01-2007, 09:35 PM
Da Swami's Avatar
Might want to try the Percy's gaskets. Sometimes aftermarket headers don't mate up super nice to aftermarket heads, but I've seen Percy's do the trick when GM MLS didn't.
