Largest pushrod diameter in stock holes ?
I want to order a custom set from Trend . 3/8'' diameter, .135'' wall thickness, 7.425'' length
Will these work without machine work ? For reference a normal performance Gen 3 pushrod is 5/16'' diameter , .080'' wall thickness .
Have #241 castings if makes a difference .
Ends can be tapered to 5/16'' . Just wondering if the pushrod holes in the stock heads will allow for a 3/8'' diameter pushrod without machine work ?
Setup
LG Motorsports X3 234/242 @.050 .598''/.610'' 112lsa+4
PAC - 1518 0.650" Nitrided Beehive springs
Texas Speed / PRC Titainuim retainers
Yella Terra Ultra-lite rockers 1.7
LS2 timing set
Melling oil pump
Setup
LS2 timing set
Melling oil pump
