Can somebody please post up flow numbers for stock 02+ LS6 heads?
Old 10-11-2007, 10:34 PM
Chicago Crew UnderBoss's Avatar
Default Can somebody please post up flow numbers for stock 02+ LS6 heads?
Thank you very much!
Old 10-11-2007, 10:36 PM
santiago's Avatar
-------241--ls6---806--862{5.3l
200 - 134 -135 - 127 - 128
300 - 185 -186 - 179 - 176
400 - 216 -220 - 212 - 204
450 - 222 -233 - 214 - 213
500 - 226 -238 - 220 - 216
550 - 228 -238 - 220 - 210
600 - 228 -236 - 221 - 210
Old 10-11-2007, 10:38 PM
santiago's Avatar
another
https://ls1tech.com/forums/showpost....7&postcount=28
Old 10-12-2007, 11:50 AM
Jedi Master
Gh0st's Avatar
I'm assuming ported heads will flow better at 600 lift. Looks like my cam is going to be choked a little
Old 10-12-2007, 11:55 AM
THEBRAD's Avatar
that covers some of the heads but what about say the 243 non ls6 heads?
Old 10-12-2007, 11:57 AM
Jedi Master
Gh0st's Avatar
Wouldn't the flow numbers be the same? I thought the only difference between the two was that the LS6 heads have sodium filled valves?
Old 10-12-2007, 01:15 PM
That's right, the heads are identical to LS6 heads except for the sodium filled valves and the flow numbers would be indentical.
SANTIAGO, thanks for posting the above I did not realize stock LS6 heads in these ranges which are way less than a good ported LS6 head.
Old 10-12-2007, 03:51 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I made a chart a long time ago using the info in that thread:
A little easier for me to look at than a bunch of numbers
Old 10-12-2007, 04:00 PM
oz304's Avatar
thanks dude ,been looking for these as well.
Old 10-12-2007, 04:06 PM
2000KnightRider's Avatar
Stock 5.3 Heads
Chamber 61.15 cc 0.100 0.200 0.300 0.400 0.500 0.550 0.600
Intake 200 cc 63 128 179 210 218 221 226
Exhaust 70 cc 54 93 121 145 163 168 174
Valve Diameter Intake 1.89"
Valve Diameter Exhaust 1.55"
Part Number 12559852
12561706
Stock 6.0 Heads
Chamber 71.0 cc 0.100 0.200 0.300 0.400 0.500 0.550 0.600
Intake ??? 66 142 196 228 236 238 240
Exhaust ??? 59 104 137 155 167 173 177
Valve Diameter Intake 2.00"
Stock LS1 Heads
Chamber 66.67 cc 0.100 0.200 0.300 0.400 0.500 0.550 0.600
Intake 200 cc 67 122 178 215 219 223 227
Exhaust 70 cc 52 97 133 156 170 176 180
Part Number 12559853 (1997-98)
12559853 (1999-00)
12564241 (2001-03)
Stock LS6 Heads
Chamber 64.45 cc 0.100 0.200 0.300 0.400 0.500 0.550 0.600
Intake 210 cc 62 126 184 224 251 256 257
Exhaust 75 cc 57 108 143 163 176 180 183
Part Number 12564243 (2001 +Z06)
Quick Reply: Can somebody please post up flow numbers for stock 02+ LS6 heads?
