Identifying Stock Valve Springs? How?
Old 10-12-2007, 10:40 AM
LS1GMCTruck's Avatar
Question Identifying Stock Valve Springs? How?
How do I tell if my 2001 LS1 Camaro SS engine has the stock valve springs, or if they have been upgraded? Thanks
Old 10-12-2007, 11:22 AM
gillbot's Avatar
Just buy new ones if you think they need changed. It's cheap insurance vs. the cost of a motor.
Old 10-12-2007, 11:52 PM
CAMAROZ28SS's Avatar
X2. you dont want to use the wrong springs. that can result in a flat cam
Old 10-13-2007, 12:16 AM
PREDATOR-Z's Avatar
Back to the top.
LS1 have beehive, so the only replacements that look alike are Comp 918, and LS2/LS6
918s have a blue stripe, LS6 (late model 02+) Yellow or orange
Another way is to measure the seat pressures.
Old 10-13-2007, 10:40 AM
Default Stock LS1 Valve Springs
Originally Posted by PREDATOR-Z
Back to the top.
Gotcha...Thanks. Where does one buy an affordable, but accurate, valve spring tension tool?
Old 10-15-2007, 07:05 AM
Question Valve Spring Tension
Does each spring have to be removed & bench tested, or is there a tool that can be used with them still installed? I will check Summit, Jeg's, etc. Thanks
Old 10-15-2007, 09:47 AM
PREDATOR-Z's Avatar
Yeap, each spring would have to be removed and bench tested.
