918 springs with a torquer2 cam
Scammer Alert!
hey i was looking at buying the tsp torquer 2 cam an dgetting the 918 springs, it says springs are good to 600 lift and proven good in applications up to .625 lift, what does everyone think?
You could try SDPC and get a set of there black box springs, which are basically as good if not better then the comp 918. Considerable price difference as well. Ill be using them on my setup and as opposed to the 918's i havent heard of these breaking like the 918's. I was turned on to these while doing a search and looking at the 918's. Link is included
http://www.sdparts.com/product/SDL16...S1Setof16.aspx
That depends on the LSA/ICL of that cam and shift points are "trial and error" at track (to determine the best), otherwise rule of thumb is 300>500 rpm past peak.
