n2o and stock crank
Old 10-12-2007, 11:13 PM
suicidal racing's Avatar
Default n2o and stock crank
how much can a stock crank take?
say 650hp on motor then what would be the max shot size would you run..pistons and rods forged.
this would be a fogger and a good safe tune in it.
200,300 or 400 shot total?
Old 10-12-2007, 11:28 PM
blueeyeddevil141's Avatar
Stock crank has been proven past 900hp, many times.
Old 10-12-2007, 11:31 PM
yeah i've read that but all where turbo set ups..so i wasn't sure about it..guess i'm going to go n2o..was thinking pt88 and a blow threw but hell i will just stick with something i know good.
Old 10-13-2007, 07:54 AM
Benjamin Russick's Avatar
The stock crank is tough, no doubt, but I'd get a little worried above 700rwhp. If I'm planning on making that much power, $1700 for a forged crank and some peace of mind is worth it to me.
I'm also not sure I'd hit my forged 383 with much more than a 200shot, but I'm a sissy like that. Good luck!
Old 10-13-2007, 12:07 PM
yeah i push **** to there limits.i had a 1969 2 bolt main 327 that had stock rods and crank..just swaped rod bolts and i hit it with a 150 shot..engine made around 750hp total.
Old 10-13-2007, 12:33 PM
1_bad_TA's Avatar
I would buy a new crank. Do you really want to blow it up because you went cheap with a factory crank?
Old 10-13-2007, 12:53 PM
Snyper's Avatar
Id say your going to be completely fine with that crank. Im hitting my car with a 200 shot and im using stock rods and crank..id say no more than a 250 shot if you want it to live but it will take more..just not reliably.
Old 10-13-2007, 01:09 PM
=ZoomZ='s Avatar
Its not the crank you need to worry about , its the main cap bolts , rod bolts and lifting the heads .
ARP fastners through out the motor with forged rods , pistons and head studs .
200-250 shot is easy .
300 shot will start lifting the heads on an aluminum block after a few passes .
Old 10-13-2007, 02:23 PM
going to use a lq4 block,stock crank,carrillo rods and diamond pistons.
arp stuff will be in the block,i should be fine i think..looks like they snap around 1100 or 1200 so 900hp i should be good crank will be a new factory peice.
this is going to be a grudge car so it wont see alot of miles.
Old 10-13-2007, 03:41 PM
=ZoomZ='s Avatar
11.8:1 and a 300 is what im running on an LQ9 , AFR 225"s 238/242 , Calies crank , lunati billet rods and diamond nitrous pistons .
It should go 9.6-9.8 easy .
20 degrees of timing , TR9's and 116 fuel .
