cam install for A4??
I've done three cam installs on m6 ls1 but this is my first for an auto car, whats different if anything. I was told I have to drop the starter for some reason.
On an A4 car, you'll need to drop the starter and either install the flywheel locking tool or wedge a screwdriver in. The starter is held in by 2 13mm bolts for 99+ models or 2 15mm bolts for 98 models and is on the bottom rear passenger side of the engine. You can leave the wires attached.
