Car just went nuts
Old 10-15-2007, 02:03 AM
Jrp1978's Avatar
Default Car just went nuts
On the way home tonight after the head can cam install . I drove about 20 miles and when i got to my home town the mph and tach stop working and the car started running like dog **** and kinda knocking and now it wont start . What the hell did i do now?
Old 10-15-2007, 02:14 AM
odarabla's Avatar
Is air coming out of the intake?
Old 10-15-2007, 10:07 AM
Jrp1978's Avatar
Default not sure
i am headed out know to investigate
Old 10-15-2007, 10:11 AM
tilly's Avatar
did you forget to connect a ground wire or didnt tighten up all your grounds ?
Old 10-15-2007, 10:15 AM
Jrp1978's Avatar
Default dont thinkk so
there was three of them of the back of the driver side head . I put all of them together and then tightened the bolt
Old 10-15-2007, 11:13 AM
BIG_MIKE2005's Avatar
I'm suprised it even ran that way.
I did that on mine & it wouldn't even fire up. I had to go back & look at my buddies motor & then put my grounds exactly like they were before removing them. Then the car fired right up & haven't had a issue since.
Old 10-15-2007, 03:19 PM
tilly's Avatar
there are more than those 3 ground wires, there are a few, I think one is mounted on the motor mount or close to it on drivers side and one towards the rear on the passenger side behind the motor mount
Old 10-15-2007, 04:04 PM
You'll never touch those for a basic H/C install unless you drop the motor out the bottom which is way too much work.
Old 10-15-2007, 04:23 PM
cablebandit's Avatar
sounds like you broke the crank position wire or almost at least
Old 10-16-2007, 03:30 PM
Da Swami's Avatar
I doubt it would have started in the first place if that had happened.
It definitely sounds like a ground problem, considering it was doing fine for awhile there.
Old 10-16-2007, 10:07 PM
ISeeRed's Avatar
Check to see if any wires melted against the manifold or headers...it seems that everything worked until something arced out...maybe melted??
