Oil level sensor location- F body
Old 10-16-2007, 09:55 AM
V8 Supra Builder's Avatar
Default Oil level sensor location- F body
I hope this is the correct forum for this question.
I am putting a Gen 3 V8 into a BMW & have bought an aftermarket Moroso pan. It has no provision for the oil level sensor. I may omit this part, but if I can locate/make a bung/nut for the sensor, I would like to have it. The pan uses the F body dipstick, so it looks like the sensor location should be the same.
I need someone with an F body oil pan to measure the location of the oil level sensor from:
1) The top rail of the pan and
2) The rear edge of the pan
I need the measurements from the edges to the center of the opening if possible.
Thanks for any help.
Old 10-16-2007, 05:28 PM
8a8mfh's Avatar
The measurements may do you no good if the pan has different dimensions than a stock pan.
Old 10-16-2007, 05:54 PM
The dimensions are indeed different (that is why I'm using it ), but since it uses the same dipstick, the oil level requirement will remain the same.
