View Poll Results: delete or keep pcv
Delete pcv and put breathers?
23
31.94%
keep pcv and put a catch can?
49
68.06%
Voters: 72. You may not vote on this poll
keep pcv or delete it?
Old 10-17-2007, 01:56 AM
headed-ws6's Avatar
Default keep pcv or delete it?
I know this has been talked about for years, but I havent seen any real clear cut negatives besides crankcase pressure building up. what are the side effects that ya'll have had with removing your pcv. it seems to be 50/50 on whether to keep it or delete give me what you think.
Old 10-17-2007, 05:16 AM
DCx
DCx's Avatar
i just posted a complete brand new ls6 pcv system in the classifieds.
Old 10-17-2007, 05:30 AM
Thule's Avatar
i installed a newer style pcv system in my 98Z when i deleted the egr system and smog pump, and new style heads,
i hate all those hoses.. so i bougth valve covers and breathers, i can let you know how it works out if you want
Old 10-17-2007, 05:43 AM
SS101's Avatar
breathers are a simple and effective solution, but a lot of people end up coating their engine bays with the oil that is expelled thru them.
Old 10-17-2007, 06:06 AM
Thule's Avatar
that is what i am afraid of,
isn't there a way to make an oil catch can and use breathers?
Old 10-17-2007, 11:49 AM
SS101's Avatar
some guys like to put a breather on top of a catch can...deseptively simple but i hear it works pretty well
Old 10-17-2007, 08:48 PM
headed-ws6's Avatar
Is the ls6 valley cover worth the 160$?
Old 10-17-2007, 08:51 PM
3.4camaro's Avatar
Put a breather on. Way easier.
Old 10-17-2007, 08:59 PM
Cstick's Avatar
Keep the PCV and add a catchcan. When I had breathers a gas smelling ooze would form at the neck where I had the breathers and eventually plug the breathers. I went to a cheap air compressor type filter and put the PCV back on.
Old 10-17-2007, 11:44 PM
99blancoSS's Avatar
I tried it all and eventualy went to basicaly an extended breather system using a vented catch can.
The tube from valve cover to tb is not part of the catch can system. The catch goes inbetween the pcv and the intake manifold. Thats why some people still have an oil problem even though they have a catch can.
I found that the only way to truely keep the oil from getting into the intake was to remove the whole system. Run a large diameter line from the oil cap to a vented catch.
Got rid of egr secondary air and pcv system. Car runs great , doesnt eat oil anymore.
Basics: Engine runs, builds heat gases expand need to be released. Cars used to be vented to atmosphere but the EPA changed that. This pressures gas contains atomomized oil. Each car mfg came up with a way to feed that oil laden gaseous air back into the intake and make the car eat it.
The ls1 has an extra tube from the pass valve cover to the TB and it enters before the blade. This is either fresh air in or pressure out, not real sure of its purpose to be honest with you, in my car it was a transport for oil to the tb blade so its gone. I have pictures of my setup in my fquick stuff. I mounted the can where there was room it it didnt look to bad. I run a 3/4" NHRA approved line and a moroso vented can.
Old 01-25-2008, 09:39 AM
Bad Blue WS6's Avatar
WOW,,i paid 97.00 bux for mine through my local dealer...even came with the bolts
Old 01-30-2008, 07:11 PM
phoenix1987's Avatar
LOL
I bought mine last year from the dealer new for 60-70 bucks.
Old 01-30-2008, 07:20 PM
SmaknaSS's Avatar
I would first make a Home depot catch can out of PVC pipe and wire mesh and see if that works first. I tried it on my first LS1 and it worked fine. But on the car in the sig the Home depot catch can nor the AMW catch can worked at all, I still got oil mist through the catch can into the intake. Finally, the only thing that's worked for me was dual breathers.
Old 01-30-2008, 08:42 PM
cdavis01's Avatar
I deleted mine, and about week later after my cam install a massive oil leak occured. Then kept trying to firgure out with the oil was coming from but couldnt tell b/c it was blowed all over the bottom of the car. Then i just decided to put the pcv system back on washed the bottom of the car off and the leak stopped
Old 01-30-2008, 09:42 PM
Steve01SS's Avatar
Most likely due to backpressure from not breathing.
Tried the catchcan and junk, pain in the *** and still managed to suck oil. I know 4 other people including that deleted PCV and used breathers... no more oil in the intake. Have to wipe off the breather now and then.. big deal.lol.
Old 01-31-2008, 06:50 AM
Randy WS6's Avatar
I use down pipes off each valve covers ,that goes under the car.
Old 01-31-2008, 09:19 AM
Sigforty's Avatar
I pulled my pcv and put a breather on the pass side in the oil fill neck. I then looped my ls6 valley cover to the pass side valve cover. I am not having any oil spray issues, and now my intake stays oil free as well.
Old 01-31-2008, 09:41 AM
slt200mph's Avatar
I run the LS6 valley cover and LS6 PCV system with a breather in the oil fill hole on the pass side valve cover. The valve covers are from GMPP and have no holes or fitting on them. I welded a baffle under the oil fill hole to keep the oil from the rocker arms from throwing a lot of oil up into the breather..I clean the breather once a month with brake clean and compressed air. I have been running this combination of parts for about 40,000 miles now with no problems.
Old 01-31-2008, 09:19 PM
SmaknaSS's Avatar
Even though I have dual filter/breathers on the valve covers, in addition I'm doing something similar to what your doing. I have one hose going from the LS6 valley cover, and two from the passengers side valve cover all tied together running behind the passengers side head right above the bell housing(No catch can or filters). No oil seems to be splashing down in that area also. I did this because my dip stick would pop out a 1/2 an inch some times and still does even though I have all these PCV vents and my compression test are good.
Nice engine BTW.
Old 02-01-2008, 10:04 AM
slt200mph's Avatar
Nice engine BTW.
Thanks for the kind words sir. Yours looks great too! With your dipstick still being pushed out it sounds like even with all of your venting you may still have some pressure building up in the engine. I am surprised that you do with your setup. It seems like it would be impossible concidering how much venting you have...
Quick Reply: keep pcv or delete it?
