Real qick question...diff btw M6 and A4..cant find in search
Old 06-10-2003, 10:16 PM
Revelation222's Avatar
Default Real qick question...diff btw M6 and A4..cant find in search
Please pardon my ingnorance.
Im new to the ls1 game.
Old 06-10-2003, 10:23 PM
CI_LS1's Avatar
Default Re: Real qick question...diff btw M6 and A4..cant find in search
Um, pedal count?
A4=4L60E
M6=Tremec T-56
Shouldn't this be in transmisson? I don't think the engine internals are much different stock a4 to stock M6, but some custom engines are built with more valve clearance in M6 apps in case of overrev/ missed 3-4 shift.
Old 06-10-2003, 10:24 PM
wrencher
wrencher's Avatar
The diff is manual or an automatic trans? think that answers your question
Old 06-10-2003, 10:33 PM
Thanks, i thought so, but wasent sure if the trans was the only thing. Muchas Gracias
Cal
Cal's Avatar
M6's have two overdrive ratios, wheres A4's have only one. This gives the M6 a wider range and allows you to run better performance ratios in the rear differential before you start to notice a hit in fuel economy. I run a 4.11 axle ratio and get virtually the same fuel economy as I did with the stock 3.42's. A3's have a stock ratio of 3.23 or 2.73.
