Benefit of better plugs?
The benefit of double platinum plugs is that they last longer. None perform better than the other recomended plug. You can pick up a few HP with synthetic oil and syn.tranny fluid
I think it is more of a benefit of having the right plug, not a better plug. If you are talking about making more power. Just get the right heat range, gap correctly and it'll be ok. If running stock compression, stock plugs should work fine. Or an equal.
