ls6 cam with stock 241 casting springs
Old 10-22-2007, 12:54 AM
hnaskoct's Avatar
Default ls6 cam with stock 241 casting springs
is the ls6 gonna be ok with the stock ls1 springs are do i have to put bigger springs??
Old 10-22-2007, 01:05 AM
Evans752's Avatar
No the stock springs wont be enough. Run Comp Cams 918 springs with 7.40 pushrods. The 918 are rated to 600 lift.
Old 10-22-2007, 11:13 AM
hnaskoct's Avatar
ok thanks
Old 10-22-2007, 11:40 AM
2xLS1's Avatar
Comp 918 spring quality is really suspect right now. Just get the GM LS6 spring kit, part # 12499224. You can get them for $65 or less from any GM dealer or SDPC.
Old 10-22-2007, 01:28 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
I'd get these LS6 springs and call it a day!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 10-22-2007, 02:53 PM
93redBIRDman's Avatar
yea I honestly wouldnt run the stock LS1 springs with anything other than a stock LS1 cam. From what I've read they are barely good enough for the stock cam, so spend $65 and get the LS6 springs...cheap insurance...
