Stock LS6 Heads and Cam
Old 10-23-2007, 08:24 PM
vtirocz's Avatar
Default Stock LS6 Heads and Cam
Where is the cheapest place to get stock (new) LS6 Heads and Cam? Summit sells the kit for ~$1850 (w/ gaskets and hardware).. anyone find a cheaper place than Summit?
Also, will '00 LS1 injectors be ok with LS6 heads/cam or do I need to go to a higher flowrate?
Thanks.
Old 10-23-2007, 08:39 PM
sidewayz28's Avatar
ok- you can find LS6 heads for an easy $500.. a cam package with springs, push rods = $600.. way less then what summit advertises.. your stock injectors will work fine if you keep the cam relatively small.
Old 10-23-2007, 09:03 PM
ChucksZ06's Avatar
I would check with gunnar at Patriot if you want new heads for a used price...He is a great guy to deal with. Chuck
Old 10-23-2007, 10:46 PM
JRracing's Avatar
Ya I would check patriots price for the ls6 heads ported. And you can get good springs with it. Then get a good used cam. That would put you at about the price of summit but with up graded parts.
Old 10-24-2007, 09:27 AM
01LS6SS's Avatar
I got mine at summit 2 years ago for $1799. With 20K miles on it since install! LOVE IT! Its in a stock 01SS, my stock injectors worked fine!
-Dan
Old 10-24-2007, 10:04 AM
14 Second Truck Club
mzoomora's Avatar
You can buy ported 243's for about $1000 or a little over. The Patriots also come with gold springs and titanium retainers. I am sure you could call them about unported stock castings also. Add in a CheaTR cam or similar and you would be cheaper than the Summit package, stockish idle and great power. Or you could find a used LS6 cam.
http://www.patriot-performance.com/w...06263&DID=1225
http://www.texas-speed.com/shop/item...d=649&catid=40
BTW- I have a set of Patriot LS6 heads, and they work great. Track times are good for a full weight car, the price was great, and he was a great guy to deal with.
