what is the best cam for 243 heads LS6
i have Stock 243 LS6 heads i want the good cam what u advise me ? MS3 , MS4 , T-rex or GX5 i have 4.10 gears i want over 420 HP
228/232 .600/.600 112+5 (hr5 lobes)
expect 35-45+rwhp, 30+trq.
car will pull hard from 3200-6400.
just dynoed an a4 car this weekend with that profile, i will try to post up a graph, or give u peak hp and trq. numbers.
numbers on a dynojet w/convertor locked in 3rd gear= 398hp, 395trq. SAE
i will try to post graph later. hope this helps.
I got the G5x3 with ported 243 heads and made 450/411 will LG headers, powerbond pulley, and ported TB. Don't forget to upgrade springs, i went with the PRC duals.
dude if your planning on using your car as a daily driver in Kuwait then good luck.
I've seen these cam in action and they made big HP's but you know the law here in Kuwait if you have a loud they will pound it !
LG Motorsports sells them http://lgmotorsports.com
There are a buch of dyno sheets on LG website with different combinations, there is a stock z06 with the G5X3 cam and LG headers makeing 432rwhp, so you should be able to make 420
http://lgmotorsports.com/gallery/thu...album=3&page=2
