Am I the only one running Raging Motorsports heads?
Am I the only one running Raging Motorsports StageII heads? Haven't dynoed yet, but the power is definitly there. I highly recommend Mark, @ Raging Motorsports.
Re: Am I the only one running Raging Motorsports heads?
Get that thing to the dyno!!!! If you are on the TR224 tuning I'll bet you will find some more ponies with a tune. Do you have a clip you could post with the idle? Did you get the idle figured out?
Randy
Randy
No your not the only one with RMS heads..there are several others and a few more being put on this week here at the shop.
I'm ready to see some times and numbers from ya.
Hey Mark, I drilled a 1/4 hole in the T.B, and the damn thing still wont idle. I adjusted the set screw again on the T.B as well, and still no luck. Is there anyway since your in Kansas (as is ED WRONG) Would you be able to get the lock code from him, so I can send you my PCM to play that "Mail order tuning game!" As soon as I can get this car to idle, trust me, I'll have dyno numbers for you.
