tach dont work after h/c install
Formerly darynC-10/23/10
any suggestions ...i went over everything atleast 5 times and everything is buttoned up nicely.... anything i could have missed?
Top side back of the block near the oil pressure sender is a low profile connector that's for the cam sensor I think. Hard to see anything back there with the intake on. Maybe you missed that connector.
also there are three ground wires on the back of the driver side head, two are screwed down with a bolt and the other has its own bolt. the two that use the same bolt are very short and right next to each other. make sure those guys are tight and in the right places, i had the same problem. ive heard if those wires arent exactly the way they came off youll have problems with that.
