What heads would you suggest for my setup?
Old 11-02-2007, 07:34 PM
jt76's Avatar
Default What heads would you suggest for my setup?
I am thinking about adding heads to my 2000 Trans am before i have it dyno tuned in the spring. What ones would you guys reccomend?
my current mods are:
pacesetter LT
pacesetter ory
borla catback
thunder racing 231/237 112LSA (hardned push rods, titanium retainers etc)
SLP lid and ram air
FAST 90/90
upgraded T56, driveshaft and ford 9" and BMR suspension goodies
I was looking at AFR 205 heads but they are a bit pricey.. what would you guys suggest or what do you use? thanks
Old 11-02-2007, 09:03 PM
99blancoSS's Avatar
set a budget and go from there, used heads arent a bad way to either
Old 11-02-2007, 11:19 PM
jt76's Avatar
im just looking to see what other's setups are and what kind of power they are putting down, as long as its around 2 grand or under
Old 11-03-2007, 02:04 AM
99blancoSS's Avatar
Do a search, look in the dyno section. Plenty of threads with info. 2k is in the AFR range. Patriot 243 heads
Old 11-03-2007, 02:32 AM
allthrotle's Avatar
If your looking for power on a budget then Id say go with partriot stage 2 ls6 heads with 59cc chambers. Thats what Im using and I made decent power with them.
Old 11-03-2007, 01:17 PM
1997bird's Avatar
I would use the Livernois stage 2 heads if you are on a budget. They made better power in a cylinder head shoot out than some of the other aftermarket cylinder heads.
http://www.livernoismotorsports.com/...t.phtml?p=1351
http://www.gmhightechperformance.com...ads/index.html
