LS1 + TSP V.3.... what else do I need?
I was watching a clip on here of a SWEEEET Camaro with a TSP Magic Stick V.3 in it. Sounded really really nice. Perfect for my taste
What else would you have to do to a motor to handle that cam? The specs are:
TSP XS Series Camshaft:
Magic Stick V.3 237/242 .603/.609"
I know on the TSP website it mentions they use it in stock heads. What is the max lift of a stock LS1 head?
I would think the intake/throttle body would be necessary, but what about anything else? Heads? Springs just to be safe? Any thing on the bottom end?
Just looking for some sound advice (yeah, I'm new).
Thanks guys,
Barry
Thanks guys,
Barry
you'll need springs.... stock intake/tb will work...
anyone else wanna chime in and help the man out lol
Thanks for the responses guys. That helps out a lot.
I might post this as a new thread, but thought I'd add it to this one:
If I used the M3 cam in an LS2, would I need the spring changes? I cannot find the differences of the LS2 heads vs the LS1 heads. I know that they said the LS2 engines have the LS6 heads, which were apparently better as stock vs the LS1 heads (Is that true?). So I guess that I really have 4questions now:
1. Do the LS2 engines have the LS6 heads on them?
2. What is the difference of LS6 heads vs LS1 heads (besides flow)? Springs, valve sizes, etc?
3. Would adding the M3 cam be acceptable to do to a stock LS2 without chaning anything in the heads, intake, throttle body? (Would I need pushrods, springs, or anything else like recommended on an LS1?)
4. With the M3 cam, would I benefit anything from running the FAST 90/90 compared to the stockers on the LS2?
Thanks again!!
Thanks again!!
No, they have 243 castings, same as LS6 but solid valves instead of hollow
Better runner shape, chamber shape, chamber size and yes the valves although same diameter but taller
Yes it would fit
FAST 90/90 should pick up power
Thanks again!!
Yes it would fit
Thanks again!!
Please read the JRP cam sticky and Patrick G sticky to better understand.
I like the dark side so far..... I see no reason to stick with the normal small block Chevy anymore, so I'm here to stay!!!
Thanks for the replies everyone, your answers cleared some stuff up for me. And Predator, I WILL read the stickys you mentioned for sure. I guess I didn't catch them yet, I was looking at the HP Dyno/Cam sticky for a while, and some other cam question threads to see if anyone had the same questions I do.
Basically the way I'm understanding it so far is like this:
If you want a cam like the M3 in an LS1, it would also need new springs, pushrods, and oil pump.
If you want a cam like the MS3 in an LS2, it wouldn't really need anything (maybe the oil pump upgrade).
And the benefit of the LS2 is that it has better heads and better intake. The TB would probably have to be converted to a cable driven one. Is that a fair assumption?
In the general opinion on here, to keep the starting point even, lets just say someone wanted to strictly buy a crate engine. And they were looking at an LS1 and an LS2. To get by for a few years, they only intended to put a M3 cam in it, and of course open up the air box on the car, underdrive pulley, no power steering pump, no air conditioning. Which crate engine would be the better starting point based on money spent in the end to get the M3 into the motor without jeopardizing other valve train parts?
I'm kinda seeing it as the LS2 would be a better starting point for me???? My car is basically a blank canvas. Here's a link to what I'm working with so far. Don't laugh, she's all I could afford from the start;
http://community.webshots.com/user/66BADBOY
So I can start with either motor. But there's always the option that I could start with a used 2001 LS1, I just don't know if I can find one with low mileage. I'm always afraid to start with someone elses problems, so I was kinda thinking about starting with a crate.
Sorry for the rambling!!
Thanks guys!!!
If you want a cam like the M3 in an LS1, it would also need new springs, pushrods, and oil pump.(Quote)
If you want a cam like the MS3 in an LS2, it wouldn't really need anything (maybe the oil pump upgrade). (Quote)
As them gentalmen said above. You MUST change spings and pushrods on any LS platform with a cam swap. Unless your putting another stock size cam back in which is pointless. Have fun with the car.
You can run other cams on stock LS6 & LS2 (Like Old man cam, LPE GT2-3)
Basicaly any cam that doesn't require more seat pressures than the springs can handle.
