Trying to look at the bright side !
So i am sure you are all tired of hearing about my car and the fact that is still not back together. Anyway So this is what i have Torquer v3 cam ls6 stg2.5 heads 202 valves . All bolt on you can think of ls6 intake pp throttle body . m12 transmission 410 gears . Kinda wondering what you all think if might run after i get it back together? Or hopeful i get it there . Just looking for a little bit of good out all this **** that has happen in 3 weeks oh and it got a patrick g tune hit me up with prediction on dyno #
With just a tr224 a m6 trans and 410 gears i made it to 8.05 at 90 mph short time of 1.84 bogging like hell1
Sure
What kinda info are you wanting ? Its a trany out of 06 gto its got taller gears
2.97 2.66
2.07 1.78
1.43 1.30
1.00 1.00
.84 .74
.56 .50
m12 m6
The m6 came stock in the f body . the m12 is in gto 2004 to 2006 and vettes
much much stonger. 700hp 700 ftbls that is what amber a 6 speed inc told me this will hold . They are the one that built it!
2.97 2.66
2.07 1.78
1.43 1.30
1.00 1.00
.84 .74
.56 .50
m12 m6
gm page
Six Speed Manual Transmissions
RPO Trans Name First Second Third Fourth Fifth Sixth
M10 Tremec 85mm 3.010 0.840 0.570
M12 Tremec T56 2.970 2.070 1.430 1.000 0.840 0.570
ML6 ZF S6-650 5.790 3.310 2.100 1.310 1.000 0.720
ML9 ZF S6-40 2.640 1.800 1.290 1.000 0.750 0.490
MM6 Tremec T56 2.660 1.780 1.300 1.000 0.740 0.500
MV1 Aisin 85mm 4.170 0.790
MV6 Aisin 85mm 4.170 0.790
MZ6 Tremec 85mm 2.970 2.070 1.430 1.000 0.710 0.570
