should I change the oil pump?
Old 11-04-2007, 05:55 PM
Soul TKR's Avatar
Default should I change the oil pump?
got 118k miles on the car... having a new 224/224 114 cam put in right now... while in there should I have the stock oil pump replaced? or is it one of those "if it's not broken don't fix it things"?
if so... which pump will suffice?
Old 11-04-2007, 06:04 PM
Zitty'sZ's Avatar
I would definately change that oil pump while I had it apart and as far as which pump to use , a stock ls6 , SLP , and Melling seem to be the most prefered choices .
Old 11-04-2007, 06:06 PM
Ericbigmac83's Avatar
yup, it would be smart to put on a ported one, only $130ish. Ive got the melling one
Old 11-04-2007, 06:49 PM
Soul TKR's Avatar
so would this be a good replacement?
http://cgi.ebay.com/ebaymotors/High-...spagenameZWD1V
Old 11-04-2007, 06:53 PM
Grimes's Avatar
that would work....lots of ppl buy ported stock ones or you could try a melling
Zitty'sZ's Avatar
Yes sir, that would be just fine !
Old 11-04-2007, 06:56 PM
Soul TKR's Avatar
oh is that a ported stock one? or an ls6? (gonna read it again )
Old 11-04-2007, 08:28 PM
LS1C5Vette's Avatar
At least go LS6 but I would def change it, only another $80-$100, I got mine used with 15k miles for $40 shipped and ported and shimmed it myself in under a hour.
Old 11-05-2007, 12:17 PM
slt200mph's Avatar
They all are LS6 pumps for the last few years.
Old 11-05-2007, 01:35 PM
Internet Mechanic
BlackScreaminMachine's Avatar
I asked the same question, milage and yr of the veh made were a BIG consideration, I have 39k on a 02 t/a and I feel confident in leaving it alone, for you I would def do it.
Old 11-06-2007, 04:25 PM
1Bad00SS's Avatar
Definately, and not to state the obvious, but change the timing chain, too.
Old 11-06-2007, 04:41 PM
lastcall190's Avatar
Picked up a Melling for my motor with similar mileage and similar sized cam. Couldn't be happier. Yes do the chain as well.
-J
Old 11-06-2007, 05:35 PM
slow trap's Avatar
^ yep, throw on an ls2 chain and ls6 pump and you should be good to go. i've heard good things about the melling pumps also so that pump may be worth a consideration.
Old 11-06-2007, 05:49 PM
SmaknaSS's Avatar
If I'm not mistaken I think the some of the pre 01-02 oil pump's had a problem going out. IF not, I would still change it anyway.
Old 11-06-2007, 07:02 PM
RedRallyeZ's Avatar
melling on order for my camswap, but mines a no brainer, ive got around 101,000 on the 2000, cheap insurance becasue i cant afford a motor and my oil pressures a little lower than id like it to be
Old 11-06-2007, 07:14 PM
Dave Carney's Avatar
I wouldn't change it. You obviously got a good one. I would change put a new chain on though.
