more than 1/4mile cam
i am looking for a cam for my h/c setup the heads will be stage 2 ones, but i need help finding a cam. i am looking for something that will work for the 1/4 mile and above, and cant decide between the following:
1: tr224/224 112
2: mti x1
3: other cams
please help i'd look at other posts but they all are for 1/4 and i will need something that will work after that
my car is a 99 z28 m6 with the Following mods:
mac headers with ONroad Y pipe
borla cat back
bbk throttle body
ls6 intake
slp mass air
ls1 motorsports air lid and k&n
spec clutch stage 3
1: tr224/224 112
2: mti x1
3: other cams
borla cat back
bbk throttle body
ls6 intake
slp mass air
spec clutch stage 3
Re: more than 1/4mile cam
Well I have the GM ASA cam. It was desinged for roadracing so it definatly works after the 1/4. But I think all the cams will work great you posted as gears are a bigger factor in speeds after the 1/4 and you have to go pretty steep to really affect top speed.
I ordered the TR224 114 and I plan to go to the Bonneville Salt Flats for some land-speed racing on a 2 mile course. I don't think your motor will even notice you just passed a 1/4 mile, you'll just shift to 5th gear and keep going. It will probably be more important to worry about the cooling system, since a quarter mile is over so quick it really doesn't matter for drag racing.
Lumina,
1/4 mile and above?...like long runs at high speed?
Have a chat with the boys on WWW.LS1.COM.AU. (can't remember if you are a current member or not).
We are all LS1 Commodore owners and some of the 'spanner twirlers' might also help you out with cam and selection. Interested to see you fitted U.S. exhaust components to your car. There are some very very nice twin 2.5" systems available for your exact car in Australia along with headers that will fit like a glove.
Might see ya there soon.
sorry guys i did not make my self clear i was thinking more of something that would work with the 1/4 mile all the way to the 1/2 mile since races here will go all the way to 1000 meters
and i forgot to tell you guys the car has a 3.73 rearend ratio
ps 8pots thanks for the invite
thanks 2001CamaroGuy
i was thinking of a a more agresseve cam since i will be running a longer distance 1/2 mile and more
but since in the states you guys never run more than the 1/4 no one can help me
i'm thinking of getting something with more lift since i'm gonna be in the high rpm range most of the time
guys tell me why i'm wrong
Half mile, quarter mile, I don't see the difference; either way you have one launch at 2500 rpm then after that you will be at high rpm anyway if you are geared right for the cam you are using. The decision to go bigger comes down to driveability and the upper limit of rpm that you can turn. A TR224 will get you as high as a stock low end can handle and higher.
