Alot of pressure under the oil cap
Old 11-07-2007, 11:11 AM
Tiger2o69's Avatar
Default Alot of pressure under the oil cap
Within a few seconds of running, its building a lot pressure under the oil cap.
This is n/a car, not turbo.
Is it more likely this is a ring or a head gasket problem?
From looking in the cap, the oil looks kind of milky, so I'm assuming head gasket. But would it build up that much pressure?
Haha a/n car.. I had someone type this for me while i was at school sorry.. Anyway.. I dont have any tools here at school or I would do a compression test and change oil to see what it looks like.. I just didnt think that a head gasket would cause that much pressure.. I did look at the water and its brown so Im going with head gasket..
Now I need to decide on trailering it back to my house (80 miles) or if it would be ok to drive home. Im assuming trailering would be the best thing..
Old 11-07-2007, 02:52 PM
topher455's Avatar
Pressure in the crankcase is almost always an indicator of worn rings but if the oil in the crankcase looks like a milkshake there is def intermix of coolant and oil which is caused by a blown headgasket. It is possible that a head has cracked and is allowing cylinder pressure into the crankcase. Also if the engiine has been overheated severely the rings could be wiped out. To test your rings first do a dry then a wet compression test (wet means put some motor oil in the cylinder <just a capful>) and compare your compression readings if they they change more than 10psi your rings are probably smoked. A compression test will also help determine which cylinders are affected by the blown head gasket as they will have low compression numbers. Do yourself a favor dont be tempted to change just one gasket. Hope this helps. Chris
Old 11-07-2007, 05:04 PM
SS101's Avatar
+1 good luck!
Old 11-07-2007, 05:29 PM
Tiger2o69's Avatar
Yeah i have cometics on it so im going to take them both off and put multi layer steels back on..
Old 11-07-2007, 06:23 PM
brad8266's Avatar
Brown water is an indication of a blown gasket or cracked head. Make sure you clean the **** out of the deck surfaces and properly tighten down the heads when you assemble it. That will ensure a good seal.
Old 11-07-2007, 06:39 PM
DevistatRx7's Avatar
DO NOT DRIVE IT LIKE THAT!!! YOU will surely ruin the rest of the motor.
Old 11-09-2007, 07:12 AM
Tiger2o69's Avatar
I thought about cracked head but with the problems I have had with these heads I surely hope not.. I wont say what kind they are yet..
