What can i safely spin my motor to?
Old 11-08-2007, 09:23 PM
CAMAROZ28AQUINO's Avatar
Default What can i safely spin my motor to?
what can i safely spin too, i mean absolutely no risk in breaking something. Mods in sig, stock 98 rod bolts. thanks
Old 11-08-2007, 09:28 PM
dlc1609's Avatar
this might help....
https://ls1tech.com/forums/showthrea...lt#post6381911
Old 11-08-2007, 09:51 PM
Formerly darynC-10/23/10
Daryn's Avatar
i spin mine to 6800 without thining twice if its going to break... stock 99 rod bolts!!! booya
Old 11-08-2007, 10:03 PM
Randy WS6's Avatar
what he said.^^^
Old 11-08-2007, 10:09 PM
chuckyt1's Avatar
Lights set at 6900, limiter is at 7200. Katechs are going in this winter...
Old 11-08-2007, 10:11 PM
Daryn's Avatar
ditto katechs are goin in as soon as i get some extra cash
Old 11-09-2007, 12:26 AM
phoenix1987's Avatar
How long have you been spinin' the motor that long though?
Old 11-09-2007, 12:50 AM
Daryn's Avatar
i can truely say ive done it alot when it was my DD . though i have only done it about 5 times since the new cam and tune since tuesday.. it runs strong .
now i do believe that with stock lifters .. its a nono to spin past 6700 i have reason to believe thats what caused one of my lifter failures.
oh and with 100,000 miles . it was time for a new set of lifters anyway! and timing set, the stock one was worn to poop!
Old 11-09-2007, 01:11 AM
Prerun4fun13's Avatar
Dont spin over 6500 RPM just to be safe unless you have a built motor. I shift at around 6500.
Old 11-09-2007, 02:19 AM
Ws6man2000's Avatar
Location: Ft lewis,Ft sill and thats all i hope.Katy texas
i keep mine at 6400 just to be safe... i have arp rod bolts i need to install just too lazy
Old 11-09-2007, 07:24 AM
slow trap's Avatar
i say 6500 or so it should stay together. there will definitely be a difference of opinion on this issue but i think if you keep it below that it should last quite a while.
Old 11-09-2007, 07:37 AM
mbm88's Avatar
Don't 98's have weaker rod bolts? And just out of curiosity, how far back are the stock tachs set?
Old 11-09-2007, 08:13 AM
Blacker's Avatar
I spin mine to 6,600 rpm's with the cutoff set to 6,800 rpm's. I don't pay too much attention to the tach in my auto. For an M6, I would use a shift light since the tach is not the most accurate.
Old 11-09-2007, 08:28 AM
john563's Avatar
there is a guy on here I think his user name is 98mysticz. He put in a ms3 in his stock bottom 98 and it did not last long spinning that high. I have a 98 H/C/I and I put in katechs this summer just to be safe
Old 11-09-2007, 09:13 AM
SladeX's Avatar
I spin mine to 6500rpm a lot, I've got over 100+passes at the track this year and bounced off my 6500rpm rev limiter a few times playing on the highway.
Results with 98 cars may vary though. Just don't spend any more time up there than you need to, I tend to shift at 6400rpm on track and a few times going off a freeway on ramp heh, trying to redline first is an effort in traction futility. Doing it in second will break speed limits.... ughhh need gears now.
Old 11-09-2007, 09:20 AM
SS101's Avatar
on stock 98's just keep it below 6500k if you an help it...if you want to take the best possilbe advantage of your cam, then get some desent bolts and call it a day, otherwise, don't temp the fates. i don't know if you've ever seen an ls1 throw a piston, but it'll cost one hell of a alot more to fix then a set of good rod bolts will.
Old 11-09-2007, 09:23 AM
lilbuddy1587's Avatar
You can safely rev that motor to 7,200 rpms you just need to make sure to keep oil full at all times and keep and eye on things.
Old 11-09-2007, 09:42 AM
BES Stroked Nova's Avatar
with a 98 and your not wanting it to break, keep it below 6500
now i had my 98 with 130k miles, and i bet it seen 7200.... well to many times. but i also didnt care...
Old 11-09-2007, 10:00 AM
SSNISTR's Avatar
My limter is 6700, my shift light is 6500. Don't go by the stock tach either, it is a POS! I got a Autometer.
Old 11-09-2007, 10:22 AM
blueeyeddevil141's Avatar
This guy must be freaking out hearing not to go past 6500, and others saying going to 7200 is fine ahha.
