How Far Can I mill Stock 241 Heads????
I have a set of 241 heads i am going to port and polish. I was wondering how far i can have them milled and still be able to clear my Magic Stick 3 without fly cutting?
Besides that, you're still reducing PTV clearance. Probably need to flycut anyway.
dude you should have no problem milling the heads. I have 853 (99 ls1 heads) that are ported and are milled .055 that makes the heads a 54cc head over a 62 cc stock head. i have 2cc diamond pistons and my cam is a custom grind 228/236 581/601 113LSa. you should have no problem with milling them. and as far a flow# my 853 heads flow 308 cfm @ 600 lift intake side. that is more than the ported 243's offered by other companys. It is all who does the port work.
If the heads you run are milled for smaller chambers (as opposed to welded), then you are going to have the same problem. If you insist on avoiding a flycut, reconsider your cam choice and stick with something under 230* and wider than 110 LSA to be safe. Even at that, you should still check.
