Going with a Magic Stick 4
im thinking about putting the magic 4 and cam kit in my car i and was just just woundering if anyone knew what kinda of power i will be making and if anyone has this cam in a cam only car what kinda of times i can expect to see
what stall will and gears will you be running with that cam?
The valves will clear stock heads, but the margin of safety that it will clear with is questionable. If you run an aftermarket head it will depend on the design on the head ie... chamber size/design, valve size, sunk valves.
