i put the march pulley on and now the motor don't turn?
Old 11-11-2007, 04:20 PM
94 guy's Avatar
Default i put the march pulley on and now the motor don't turn?
what's the deal?
Old 11-11-2007, 04:47 PM
brad8266's Avatar
It isnt the pullys fault. Something else got hosed in the process of you installing it. Id start by checking the fuses first, you might have blown one.
Old 11-11-2007, 04:57 PM
vettenuts's Avatar
When you say won't turn, do you mean by hand or there is not power to the starter? Is the motor bound?
Old 11-11-2007, 05:01 PM
94 guy's Avatar
no this motor is on the stand be assembled.
Old 11-11-2007, 05:13 PM
brad8266's Avatar
Oh, if it wont hand turn then something is wrong for sure. A little background on the motor would be good.
Old 11-11-2007, 05:28 PM
94 guy's Avatar
it's brand new
Old 11-11-2007, 05:32 PM
00SS!'s Avatar
Did it turn before the install? Are the plugs in? How did you install it?
Old 11-11-2007, 07:20 PM
Slow 346's Avatar
Please dont say you hit it with a hammer and maybe messed up the thrust bearing?
Old 11-13-2007, 10:50 AM
road agent's Avatar
Default possible pulley problem
It may well be the pulley. I bought one of these when they first came out and it was not machined correctly. Part of the pulley was contacting the oil pump housing, preventing the motor from turning over. Take the pulley back off and compare to the GM one. March sent me a free replacement with no hassle. The new one works fine.
Old 11-13-2007, 06:24 PM
vettenuts's Avatar
Yep, I seem to remember issues with the March pulleys. Pull it off and see if the motor turns, that is likely your problem.
Old 11-16-2007, 01:57 PM
RedWS6 00's Avatar
I had this exact problem. I posted the question here:- https://ls1tech.com/forums/generation-iii-internal-engine/781740-engine-jamed-cant-move-pulley-wheel.html
I removed the March pulley wheel and fitted the stock and then the engine turns.
I have a ported SLP pump, I was wondering if this was slightly bigger perhaps it was jaming on the march pulley wheel.
Just out of interest what oil pump do you have fitted?
If I have to CNC a bit off the pulley wheel to make it fit, then thats okay, but how much, and where is it jamming? I kept the engine in the car and was running out of workshop time so the stock one had to go back on, and no time for investigation into this.
Old 11-16-2007, 02:04 PM
94 guy's Avatar
looks like the step on the end of the balancer is'nt machined far enough. mine has a .210 step i'm about to take another .125. the balancer hits the front of the oil pump.
Old 11-16-2007, 02:22 PM
RedWS6 00's Avatar
Hope this works for you. If too much was taken off I cant see it causing a problem if you dont get too near the oil seal, would that be right?
.125" sounds like an ideal amount to try.
Could you post your results when you've done it. Would be much appreciated.
I've done searchs in the past and couln't find anyone that had the same trouble as me, until I came accross your post.
Old 11-16-2007, 05:19 PM
Viper's Avatar
I had the issue in 2005. Here is the picture, bottom of the article, #11:
http://www.ls1howto.com/index.php?article=23
http://www.ls1howto.com/howto/fbody/...p_machined.jpg
I know it says ASP but it's the same for a March.
Old 11-16-2007, 05:53 PM
94 guy's Avatar
how much was taken off?
Old 11-16-2007, 06:34 PM
Viper's Avatar
My engine builder did not tell me. I assume he matched the picture because that's what I sent him. Sorry.
Old 12-12-2008, 11:13 AM
Arcolog2's Avatar
I just called March for the same thing and they dont know of any issues with their pulley. So who knows what I'm going to do, guess get a different pulley.
Old 12-12-2008, 11:25 AM
94 guy's Avatar
just have it machined down. talk with slowhawk on this board.
Old 12-14-2008, 09:38 AM
Arcolog2's Avatar
I am going to have a friend at work machine it down for me today (I'm electrical guy).
First I'm going to take pics with micrometer to send to March and show them how different it is from the stock pulley.
