will ls6 heads fit on an ls1? what about z06 heads?
I want to know if ls6 heads will fit on a 2000 ls1? Will z06 (not the 427)?
Is it worth doing and what is the difference?
tHERE BETTER
They Are Better But Just Stock About 15 Hp , But I Would Have Them Ported If You Have Them Off. Plane Ls6 Heads Used 350 To 500 That Is What I Have Seen Them Go For.
We offer several different head combinations including several different stages of LS6 heads. Shoot me some info. about your setup and we can get a set of heads to compliment your setup! You can also check them out online:http://www.texas-speed.com/shop/cate...MID=3&catid=40
Jon
Jon
Medic/Z28,
I like the combo you have chosen. What kind of numbers did you put down when it was tuned? What has it run at the track? I assume you are running 243's with non-sodium filled valves/hollow valve stems?
Thanks.
Thanks.
hi,
can any one compare the LS2 6.0L heads to MTI LS2 Heads....b/c i'm looking for the best and cheapst route to gaine WHP From a 2001 LS1 Engnie....For Project LS14....looking for ~400Whp from bolt ones...
Thanks !!!
Regards,
Ali
Thanks !!!
Regards,
Ali
Jon
Jon
