anyone put on a dry sump kit like this one
http://www.drysump.com/pan1d.htm
I saw this and it looks pretty neat. Anyone have any info on dry sump setups pros/cons.
TT-TECH Veteran
Re: anyone put on a dry sump kit like this one
Well it does a lot of things but one is to keep the oil off of the rotating mass (More HP). you can increase your oil capasity for help keeping temp down under road race conditions ETC... I am not an expert at all the things its good for or to say if it is benificial for daily steet use ( I don't think so.). But that is a few of the things I do know. Hope that helps you. I do not know any one running this set up, but I do remember a buddy gaining @ 50 Hp over his conventional set up, now that was on his race car not a daily driver. Good luck with it if it works post it!
