TR230 clearance!! Need Help!!!
Ok, took my car to the shop today to have my cam installed. Here is my question, the guy who was installing it said that he thought there might be some issues with the piston/valce clearance. The cam is a TR230/236 with a 111+2 lsa. I am not sure what the lift is on the cam. What scares me is the cam was spec'd for a car with 2.5tsp heads. Does this make a difference as compared with my stock heads? Oh ya, and if you need to know, I have 7.45 pushrods. Please help me with this, I cant find anything out cause everything is closed till Monday. Its killing me!!
Thanks,
Ryan
Thanks,
Ryan
If youu are running stock heads and stock head gaskets I would expect it to clear without any problem. Of course when in doubt, check it. Hopefully whoever you have doing the install is aware of how to do that. there are at least a half dozen preffered methods and they all vary.
stock heads and stock rockers should be no problem call Thunder if you was piece of mind.
There are quite a few larger cams that would create more of a PTV problem, I say no problemo here
I would suspect it to be close. IIRC, someone out my way just did a Torquer v.2 with ported 5.3 heads and it cleared. But, you'll definitely need to check. Also, make sure your mechanic checks the preload on your lifters. Those pushrods may be a bit long.
