Broke It!!
Broke It!!
Dammit, I knew to watch out for it and I STILL broke it! I think the harness was snagged on it more than it should have been. The intake moved MAYBE 1/2" and the "snap". So..what is it and how much will it cost me?..
[IMG][/IMG]
[IMG][/IMG]
Does that have to be plugged in? Or can I just go aftermarket oil psi gauge? Been wanting to add one anyhow...or do I have to pickup the psi somewhere else if I go aftermarket? $40 is part way to a quality gauge.
Don't know for sure but, if you're going after market, go mechanical.
Really, this happens all the time. If you go with another electric gauge, I think you are going to have to replace the sender anyway. The socket is available from discount auto parts places.
Good Luck...
I don't think it is more than $20. I broke mine a few years ago when doing my ls6 intake swap. And as far as the install socket Fuc- it I just used my hand it has been on for a few years and still running strong. Go to a GM dealer and pick one up I think it is like 15 bucks.
Formerly darynC-10/23/10
yeeep i remember when i broke my first one.... ive took my intake off plenty of times since then and i have not broken another i used a cresent wrinch to tighten it on also
Yea. I know what you are saying. In my case I think someone had maybe been back there before and something was snagged on it. I am not shitting when I say it moved half and inch and then snapped. I knew it was back there, but I assumed I at least had that much play!
