will lt1 rods fit ls1
i have a set of eagle forged h-beam rods 6.00" with a set of forged srp flat tops. 4.030 out of an lt1...
would this work in a ls1.. are the rod journals the same size???
and how far could i go out on a ls1 block before i start sleevin
thanks guys
thanks guys
no, they will not work on a ls1,,, you can only hone a 98 .005", and 99 newer can be honed .010" only
if you need a larger bore you need to have the block re-sleeved or look into a 6.0L block
