new TSP cam dyno numbers!
Well I hit up the dyno this evening to test out my new setup. I had an F1 cam on stock heads (which put down 394rwhp, 383 rwtq with some minor tuning (basically enough to get it driveable). I then switched over to some stage 1 LS6 heads from JPR milled .005 and tested out the new TSP cam (231/237 .598/.595 112+2) The new setup put down 430rwhp, and 397rwtq tonight. I also had a wideband done, and needless to say I was running very very rich (down into the 11 to 1 up top and no higher than 12.2 to 1 down low). So there is more in this setup for sure.
I basically have all the bolt ons. This was through a 10 bolt w/ 3.42s and the cutout open. 6 speed car.
I am working on leaning it out tonight and tomorrow and then I will be hitting the track on Sunday.
All in all, I am very impressed with both companies, and am pleased with my numbers. Now I need a rear and I'll be good to go.
Re: new TSP cam dyno numbers!
Congrats on the new #!
I'm acutally looking to go to that cam as well from their 228/224 cam...I do have one question though...what springs did u use with that cam?
TIA
Alex
TIA
Alex
TIA
Alex
TIA
Alex
LS1Tech Premium Sponsor
That is great to hear! Thats a great combo you have going there! JPR makes a great head, and the coolest part is you don't have tons of compression yet your still making great power!
Enjoy The Cam
Enjoy The Cam
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Jason
I memory serves me correct you guys are the only authorized dealer for the low cost Patriot performance head, right?
Any dyno runs with those heads and this cam? It would be one hell of a bargain!!
I'm working on getting that setup on a car to test
Jason
Jason
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Jason
Jason
I already have the cam in just need to bolt on the Patriot Heads and tune it and get some serious power out of the WS6 ... give me a call if you want to kick around the idea
Good numbers. I just ordered that cam and I'm hopeing to get around 400 rwhp on stock heads.
ClassicCollector-were did that cam peak at?
