Intake Gaskets?.
Intake Gaskets?.
Can you re-use the rubber intake gaskets? Mine look in good shape other than the seem really flat. I thought about pulling them out, and letting them "bounce back" and puting them back in. I cant find them cheaper than $60 on vendor sites..thats rediculous! Fel-Pro sells them for about $20 but I cant find a parts store who carrys them in house.
I bought a complete head/cam gasket kit from Thunder Racing when I did my swap. The replacement intake gaskets were much thicker than the ones I took out, fyi about 110k miles on my motor.
I see what you mean, the GM intake manifold gaskets are about $60. I noticed the FAST 78/90 intake gaskets are only $26 froom Thunder Racing. I don't know if these fit the LS1/6 intake though.
http://www.thunderracing.com/catalog...vid=3&pcid=177
142-54009-8 F.A.S.T. LSX Intake Port Seal (Set of 8) $25.99
Not sure where you got the price, Skoggin's should have them cheaper if you got a local dealer price. Also, the FAST intake gaskets are about $25 and stiffer gaskets as well. You might look into those. I wouldn't re-use if they are squashed. Mine were not only flattened but were full of grit too. I replaced them.
about 20 -22 at ORIELLY ,
I have re used mine several time,( but only if on same intake ) but they were less than 1- 1 1/2 year old, if I change to a differant intake then I use new
$62.46 to be exact at SDPP http://www.sdparts.com/catalog/lsgen...oldGasket.aspx
So do the Fast gaskets work on LS6 intake?
