Valvefloat Questions..... CamSwap ?'s
Hey fellas...
I just got my STS installed.. .Loving the power..
However, @ about 8psi...@ 4k and above it feels like the engine cant make anymore power...
Is this considered ValveFloat? beacuse I dont have better ValveSprings??
Also, I picked up a set of 918's and 7.4 Hardend PR's.
I figured If I was going to do all of that, I was going to put a cam in as well.
So I had two choices Im stuck Between.....
224-224-588-588-114
224-230-585-595-112
I know that a Lower LSA will cause a loss in boost, but Im not really too concerned about that..!!
Any help is appreciated guys! Thanks so much!
224-224-588-588-114
224-230-585-595-112
Valve flotation? I doubt it. Maybe its your turbo size. Yuh know you could always just crank that turbo up a couple pounds and make ur problems dissapear ha, half joking, but no it is an option
Well I have heard that the valves start to float around 8-10 psi... Its diff. for every car.. and I think thats whats going on with mine... Plus Im going the cam swap anyways, so I will see what happens!!!
