What heads/cam package for 408?
I plan to just keep bolt ons for now until I get the 408 shortblock installed. I was wondering what heads and cam packaged from TSP I should go with? Precision Race only, since I have a budget to work with.
Here are some choices:
stage 1.0 heads LS6
stage 1.5 heads 5.3L
stage 2.5 heads 5.3L
And Which cam for the selected heads?
248/254, .611"/.613"
or
233/239 595"/.603"
or
Magic Stick V.3 237/242 .603/.609
Other?
Keep in mind...what heads and cam combo would you select from above with the usage of a 408 shortblock?
Thanks so much for your suggestions.
stage 1.0 heads LS6
or
233/239 595"/.603"
or
Other?
Im no expert but i am planning to get a new 408 from tsp around the first of the year. TSP told me that the 5.3 2.5s would work but you would be holding the 408 back form its true potential. If i was you, id go with the PRC stage 3s or the Ls6 stage 3s. And a bigger cam..
LS1Tech Premium Sponsor
Dont forget the l92 cnc ported heads also! they move 350cfm & cost about what all the other options cost! We've done the stage 2.5 ls6 heads on 408s to past the 500rwhp mark!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
