opinion on doing heads cam on stock ls1 without lt's
Old 12-09-2007, 10:24 PM
2004SSS's Avatar
Default opinion on doing heads cam on stock ls1 without lt's
im trying to keep this car smog legal , since im ca that means no longtubes.
im not looking to spend a fortune on like afr's or anything. just looking for good heads with a nice cam since this is my DD. i need it to be reliable . any ideas on a cam choice with heads is appreciated.i may do some shortyes but i dont know if there will be any gains worth it. i have heard some do the truck 6.0 mani's to get some gain.
i dont know if this rule applies as to cars as im more familiar with lsx trucks. but 224/224 is pretty much the limit on size for something to pass smog.
just looking for something in the 4xx rwhp and 11's at the track if possible.
Old 12-09-2007, 10:26 PM
Tainted's Avatar
ls6 heads with a TR224 cm on a 114lsa with a set of shorties or some mids if you cans wing it.
OR maybe even look into the cheaTR package?
Old 12-09-2007, 11:25 PM
Almostryan3's Avatar
Someone on here passed pretty easily with a 228R Cam. You can try it with a real good tune.
Old 12-10-2007, 05:46 PM
2004SSS's Avatar
hmm , but remmeber it will be with stock or 6.0 mani's.
since my exhaust wont breath great with the mani, would heads even get much enough gain to be worth it with the cam?
right now the cheatr sounds pretty good but im open to suggestions.
Old 12-10-2007, 06:05 PM
kingsey's Avatar
What kinda power would the 224 on a 114 and ls6 heads put down?
Old 12-10-2007, 07:17 PM
5.3LJimmy's Avatar
If you have to keep stock manifolds I'm gonna recommend the cheater also. Some ported LS6 heads and the cheater cam will perform nicely w/ manifolds. The gains from the heads may not be as high w/o longtubes, but you will notice the improved performance enough to warrant purchasing them.
Old 12-10-2007, 07:51 PM
hammertime's Avatar
Read this:
Maximum Overlap on F-Body Stock Manifolds
Lots of good info
Old 12-10-2007, 08:02 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We've done 224 cams with PRC heads & stock manifolds. It definately limits power output, but give a good power jump with nearly no changes to driveability at all!! We have a cnc ported 241 head setup for $850 with double springs. You could install those & a camshaft for about $1350 with pushrods & gain a good 60hp atleast....
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 12-11-2007, 10:20 AM
5.3LJimmy's Avatar
^^^Now there's a good deal.^^^
Old 12-16-2007, 11:51 PM
2004SSS's Avatar
i okan to have whatever heads i use either milled if they are the same or greater cc's. what is the most compression we can safly run on pump gas? mind you pump is 91 here in ca?
can we go to 11.1 or should i stay closer to 10.1?
Old 12-17-2007, 01:25 AM
PREDATOR-Z's Avatar
It is not as much Static CR but DynamicCR that you need to watch for regarding Octane use.
There are many cams you could use. Basicaly any cam in the 210>228 intake duration with a good -6* overlap or better.
The smaller the duration the more overlap you can venture, the higher duration like a 228, I would seek less overlap to compensate.
To name a few offshelf from various vendors:
224/224 .581/.581 114 Comp Cam
224/224 .563/.563 114 TR
220/220 .581/.581 115 MTI (Stealth 1)
224/220 .581/.581 116 MTI (Stealth 2)
215/231 .60x/.57x 117 TR (CheaTR)
210/218 .5xx/.5xx 113+ (Crane/Vinci)
etc... etc..
