Can I use the 918 springs?
Gonna be buying a cam very soon, I'm going with the tsp 231/237 .598"-.595". Can I get away with using the comp 918 springs, or should I spend a little extra and get the dual springs?
LS1Tech Premium Sponsor
We've run the 918s with the 231/237 for many years. That being said the life on a double spring is so much better that I would definately go with a PRC double spring kit. I've tested our spring at 60k miles & they still have very very good pressures & probably could have gone a lot more miles!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
