Patriot stage II/III brand new or used Lingenfelter heads?
Old 12-12-2007, 02:43 PM
FCar2000TA's Avatar
Default Patriot stage II/III brand new or used Lingenfelter heads?
http://www.lingenfelter.com/Merchant...Category_Code=
versus
http://www.patriot-performance.com/w...05234&DID=1225
Ignore price, as the used Lingenfelters are about the same price as the Patriots
Old 12-12-2007, 04:04 PM
Soul TKR's Avatar
lingenfelter link don't work...
Old 12-12-2007, 04:21 PM
FCar2000TA's Avatar
Try it now
Old 12-12-2007, 04:23 PM
black01_WS6's Avatar
you can't go wrong with a brand new set of patriots. I wouldn't buy used heads as you don't know the history, and or there may be problems with the head.
Now if you wanted to get a good set of heads then look to AFR, TEA, ET et...
Soul TKR's Avatar
The patriots come with better springs and valves...
Old 12-12-2007, 04:25 PM
FCar2000TA's Avatar
I know AFR and TEA are the ****, just can't bring myself to spend $2200+ when I can get a set of LS6 ported that will come pretty close to AFR's numbers for about a $1200
Old 12-12-2007, 04:26 PM
El_Diablo's Avatar
What valves come in the stage 3 Patriots?
Old 12-12-2007, 04:27 PM
FCar2000TA's Avatar
Patriot springs for .650 lift. I have comp 921's that I can put on either head.
Old 12-12-2007, 04:28 PM
FCar2000TA's Avatar
yeah, my brother just e-mailed me and almost **** himself saying "If the Patriots are stage II or better GET THEM"
Old 12-12-2007, 04:34 PM
El_Diablo's Avatar
What valves? (not valvesprings)
Old 12-12-2007, 04:39 PM
FCar2000TA's Avatar
HAHAHAHA I can't read. My bad.
We use a new GM raw 035 casting.
Precision welded combustion chambers.
Heat treated to OEM specs.
5 axis CNC machined.
Hand detailed and assembled.
21-4N Stainless Valves
Bronze Guides
Patriot Gold .650" Dual Springs
Titanium Retainers
5 Angle Valve Job
Custom chamber sizes available
No core required
Old 12-12-2007, 05:52 PM
silver01z06's Avatar
Even though a valve will fit into a cylinder doesnt mean its the best application. Normally stage 3 heads will have like 2.08 valves. I do believe you can fit them on a stock ls1 bottom end but it can adversly effect cylinder fill.
Old 12-12-2007, 09:48 PM
1CAMWNDR's Avatar
Just tell Patriot you want a Stage II with 2.02 I and 1.57 E valves.
Old 12-12-2007, 11:21 PM
LS1 Tech Veteran
Steve Bryant's Avatar
Talk to Gunnar at Patriot. At this price point, you can't beat the new Patriots with top of the line valve train components in terms of bang for the buck.
Steve
Old 12-13-2007, 09:58 AM
FCar2000TA's Avatar
Hey, I tried to get a 427 LSX built for me, but my bank account had a seizure, so I have to do something to stay above you in HP!
Old 12-13-2007, 10:00 AM
FCar2000TA's Avatar
Steve
That is pretty much what I am hearing. Even a guy that used to own a shop locally told me that Patriot heads are a hell of a lot better then they were in the "drops a valve" days.
Old 12-13-2007, 10:50 AM
Vrbas's Avatar
Patriot gets my vote. I got my LS6 SII's in the mail this past weekend... can't wait drop them in.
Old 12-13-2007, 11:01 AM
1CAMWNDR's Avatar
Any Stage II head with the big *** cam you have will out power my Stage I-IIish Bo White heads and my torquey 226° 230° 109° LSA cam.
Old 12-13-2007, 11:16 AM
Soul TKR's Avatar
I think the overall vote goes to Patriot
Old 12-13-2007, 01:25 PM
TXZ28LS1's Avatar
im considering some patriots also!! im curious if anybody has tried there stage 2 5.3 heads
